F911E307-D708-4's avatar
Oct 02, 2021
Netgear Nighthawk M5 Restore Backup
Hi,
I've just bought a Netgear Nighthawk M5 from Telstra to use with a USG3 and found that restoring backups does not appear to work.
After customising the device I save a backup via the GUI and then perform a factory reset.  After a reboot and reconnecting I restore my backup but none of my customisations changes return.
The export.cfg (aka configuration backup) is plain text so I can see that my changes are saved, but they are not restored.
Whats the point of being able to restore a backup if all the settings are ignored?
Some insight on what the expected behaviour would be appreciated.
Cheers
No RepliesBe the first to reply
