jenpri3
Jul 17, 2023Aspirant
Netgear Nighthawk M6 MR6110 After factory reset display is in spanish
Netgear Nighthawk M6 MR6110 from AT&T. After I did a factory reset because it wasn't connecting, the display is now in spanish. Since I don't speak spanish, I can't find the setting on the router t...
JT240Z
Jul 20, 2023Luminary
Since it's in Spanish now, the best way to proceed is to do a factory reset again. This time you need to use the hardware reset method. There's a small hole on the bottom of the case near the connector side.
Just insert a device like a paperclip and hold the button down for 10 or so seconds. The device should perform a reset.
Here's the exact wordage from the manual:
To perform a factory reset using the reset button:
1. Remove battery cover, but leave the battery installed.
2. Locate the reset button.
The reset button is inside of a small hole labelled RESET.
3. Press and hold the reset button with a paper clip or similar object for up to 10
seconds.
Use only gentle pressure. Pressing too hard or using a sharp object will damage
your hotspot and might void your warranty.
4. Release the reset button.
Your mobile hotspot displays resetting…
Your mobile hotspot is reset.
I would advise you to download a copy of the manual to help with future issues. Here's a link to the manual
Nighthawk M6 Pro, Nighthawk M6 Manual (netgear.com)
