jenpri3
Jul 17, 2023Aspirant
Netgear Nighthawk M6 MR6110 from AT&T. Displays is in spanish
Netgear Nighthawk M6 MR6110 from AT&T. After I did a factory reset because it wasn't connecting, the display is now in spanish. Since I don't speak spanish, I can't find the setting on the router t...
W1lliam
Jul 17, 2023Virtuoso
Do Factory Reset again, it will pop up Language selection after booted
jenpri3
Since everything is in spanish, I can't even find Factory Reset.
- W1lliamJul 17, 2023VirtuosoThere is reset hole on the back, remove back cover, at bottom side near to the battery. Press it, with paper clip, for 10-15 seconds and release, it will first reset to factory default then reboot, you should get a language selection on LCD panel after booted.
- DevnuttsDec 02, 2023Aspirant
Thank you for this hint! You saved my day!
