jenpri3
Jul 17, 2023Aspirant
Netgear Nighthawk M6 MR6110 from AT&T. Displays is in spanish
Netgear Nighthawk M6 MR6110 from AT&T. After I did a factory reset because it wasn't connecting, the display is now in spanish. Since I don't speak spanish, I can't find the setting on the router t...
jenpri3
Since everything is in spanish, I can't even find Factory Reset.
W1lliam
Jul 17, 2023Virtuoso
There is reset hole on the back, remove back cover, at bottom side near to the battery. Press it, with paper clip, for 10-15 seconds and release, it will first reset to factory default then reboot, you should get a language selection on LCD panel after booted.
- DevnuttsDec 02, 2023Aspirant
Thank you for this hint! You saved my day!
