NighthawkHS
Apr 22, 2023Aspirant
NETGEAR Nighthawk M6 Pro - Hotspot for exams
Hi, I have internet that can sometimes be terrible, especially with power outages, so I got a NETGEAR Nighthawk M6 Pro for a hotspot to take online proctored exams. Sometimes these exams are over...
JohnPeng
Apr 23, 2023NETGEAR Expert
If you just use one WiFi client during the test, the battery can last more than 2 hours for sure. You can just use the default settings.
But it is better to make sure the location you take the test has good cellular coverage. You can go to check before the test.
Thanks
NighthawkHS
Apr 23, 2023Aspirant
Thank you. Would setting the wifi standby mode to never ensure that my computer stays connected throughout the exam?
- JohnPengApr 24, 2023NETGEAR Expert
If your laptop keeps connected to M6 WiFi, it will not go to standby. The standby timer is triggered when there is no clinet connected to the device by WiFi. But to be safe, you can set the standby timer to Never.
Thanks
- JanicebellJul 15, 2023Aspirant
Please note that setting the standby timer to "Never" means your laptop will not enter standby mode even if there are no WiFi clients connected. It's important to consider the power consumption and battery life implications when choosing this option.
