kpmmolloy
Oct 01, 2024Follower
Netgear nighthawk m6 pro and hp officejet 250 printer
Hi there ive just gotten the nighthawk m6 pro mobile router. I was trying to connect my mobile printer (hp officejet 250). However it will only connect to a guest network and not the parent netwo...
Oct 02, 2024Guru - Experienced User
are you using wpa2/wpa3 mixed mode for security on the router wifi?
