bressonr
Jul 21, 2023Aspirant
NETGEAR Nighthawk M6 Pro (MR6450) won't run without battery - error message
I bought a brand new NETGEAR Nighthawk M6 Pro (MR6450), and unfortunately it won't run without battery, despite me plugging it in with the power adapter that was supplied with the device. I get an er...
Jul 21, 2023Guru - Experienced User
could be a bad cable, dirty ends, or even just a bad power supply.
do you have a different cable/power suppy you could try?
bressonr
Jul 23, 2023Aspirant
Thanks - I tried at a different location, but with the same cable, and it seems to work. I have no idea why it doesn't work at my house... any idea where this could be? Electricity is brand new as the house was rebuilt recently.
- plemansJul 26, 2023Guru - Experienced User
thats a bit suspicious if it works elsewhere but not at your home. The power supply doesn't care a whole lot provided the power is in spec.
Got a multimeter you can check your power at your home with?
