JohnFrampton
Jan 02, 2023Aspirant
Netgear Nighthawk m6 pro mr6500 issues
We recently upgraded to this modem/router to access AT&T 5g network. We are experiencing the following problems. WIFI constantly/randomly drops out and we need to reboot the router to get the wifi ...
JohnFrampton
Feb 16, 2023Aspirant
Just an update on this. WE worked with AT$T plus Netgear and replaced our M6 Pro. We have gotten the most recent updates to the M6;s firmware but we are still having issues.
- We get the overheating message!
- We tried to run the M6 without the battery, but it will not boot up after we remove the battery. It seems to be in a loop and the Netgear screen just flashes. We want to run in AC only mode for the faster ether net port.
- I have not re-enabled the Wi-Fi. As mentioned, we purchased an Orbi system and hove it up and pretty stable without issues.
~Not sure what else I can do to try to find a solution to the AC only mode not working.
JohnPeng
Feb 16, 2023NETGEAR Expert
Thanks for the information. I will request our SE to contact you directly to find the root cause of the issue.
Could you please PM me your contact info or send email to me directly at [email protected]
Thanks
John
- crackers8199Apr 22, 2023Aspirant
JohnPeng i'm having reboot issues when dual band wifi is turned on. when i had both 2.4 and 5 turned on, it was rebooting itself or turning off randomly every 15 minutes or so...when i turn 2.4 off and go back to 5ghz only, it seems more stable.
i'm still within my return period, and this is making it a very tough call as to whether or not to keep this if i can't trust it to use both bands at the same time. it seems from previous posts that stuff like this takes forever to get fixed, which makes me think maybe i should return this and wait until it's ready for prime time to re-buy it.
- JohnPengApr 23, 2023NETGEAR Expert
Please capture a model.json file and send PM to me. Please advise which carrier you are using.
- Logon to the webui (http://192.168.1.1 ) as an administrator
- Navigate to URL http://192.168.1.1/model.json via the same browser window
- Capture the results (by selecting all + copy) and send it backThanks
John
- crackers8199Apr 23, 2023Aspirant
done. PM sent.
just as a further data point, the router hasn't rebooted or shut down since i turned off dual band wifi last night. on 5ghz only, it has been stable since then (about 18 hours or so).
