JohnFrampton
Jan 02, 2023Aspirant
Netgear Nighthawk m6 pro mr6500 issues
We recently upgraded to this modem/router to access AT&T 5g network. We are experiencing the following problems. WIFI constantly/randomly drops out and we need to reboot the router to get the wifi ...
JohnPeng
Apr 23, 2023NETGEAR Expert
crackers8199 wrote:
JohnPeng i'm having reboot issues when dual band wifi is turned on. when i had both 2.4 and 5 turned on, it was rebooting itself or turning off randomly every 15 minutes or so...when i turn 2.4 off and go back to 5ghz only, it seems more stable.
i'm still within my return period, and this is making it a very tough call as to whether or not to keep this if i can't trust it to use both bands at the same time. it seems from previous posts that stuff like this takes forever to get fixed, which makes me think maybe i should return this and wait until it's ready for prime time to re-buy it.
Please capture a model.json file and send PM to me. Please advise which carrier you are using.
- Logon to the webui (http://192.168.1.1 ) as an administrator
- Navigate to URL http://192.168.1.1/model.json via the same browser window
- Capture the results (by selecting all + copy) and send it back
Thanks
John
crackers8199
Apr 23, 2023Aspirant
done. PM sent.
just as a further data point, the router hasn't rebooted or shut down since i turned off dual band wifi last night. on 5ghz only, it has been stable since then (about 18 hours or so).
