Blu4ce's avatar
Blu4ce
Follower
Jun 23, 2022
Netgear Nighthawk M6 Pro MR6500 MTU setting
My company just purchased 4 of the Nighthawk M6 Pro routers for use on ATT FirstNet.  Our FirstNet APN requires a lower MTU than the standard 1500.  How do we change the MTU to 1428?  I don't see that option in the settings.
Thanks in advance!
Mike
  • Launch internet browser from a connected device.>login>select advanced>setup>wan setup>in mtusize field enter a value from 64-1500 the apply
    • BrianII's avatar
      BrianII
      I have the same issue and that pathway does not exist in the m6 Pro settings
  • Hey Mike, were you ever able to resolve your MTU issue on the Nighthawk M6 pro?
  • you can try with a tool, tinyurl.com/mrCONFIGTools, v4.27 RC1
