SeniorWhiz
Jul 31, 2023Follower
Netgear Nighthawk M6 Pro Repeated Internet Failures
Last September, I purchased a new Netgear Nighthawk M6 Pro 5G Hot Spot from AT&T. I set it up in my home as the main source of internet and routing, including a WI-FI Hot Spot, and a source for Ethe...
JT240Z
Aug 01, 2023Luminary
There is a more current firmware version from AT&T that may resolve some of your issues. Try to do a software update and see if it comes down. The problem you may experience is that AT&T is allocating downloads in small batches so not everyone is getting the update at the same time. I've found that the device will say your software is up to date when it is in fact not. Repeated attempts to obtain an update seems to eventually allow for the update to come down. Unfortunately, Netgear cannot speed up the process since it's totally up to AT&T to deliver the goods.
- kzbrymJan 05, 2024Initiate
Firmware upgrades never fixed anything, I have the same problem, what a disappointment the M6 is.
