THJ123
Oct 29, 2025Guide
Netgear Nighthawk M7 Pro 5G Wifi 7 Mobilruter
Hi I have bought an M7 Pro "Mod 7450" mobile router now, but which app should I use on this? I have tried several apps from Netgear, but none of them will connect. Using Iphone 15 pro. Thanks in ...
Fortra
Oct 30, 2025Luminary
Hi - THJ123, Currently Netgear App isn't compatible with the "Nighthawk MR7450" router. You have to use your "Computer Browser" to access the routers configuration settings. Providing you've login with a Admin password to get access.
