THJ123
Oct 29, 2025Guide
Netgear Nighthawk M7 Pro 5G Wifi 7 Mobilruter
Hi I have bought an M7 Pro "Mod 7450" mobile router now, but which app should I use on this? I have tried several apps from Netgear, but none of them will connect. Using Iphone 15 pro. Thanks in ...
Fortra
Nov 16, 2025Luminary
You can bet your bottom dollar, that the above info & graphic illustration, would have been helpful to many users!
THJ123
Nov 16, 2025Guide
Maybe I'm stupid, but I've done exactly what you describe, but I get a message that it doesn't support my device.
I'll stick to the web version until a new app comes out that supports this.
Thank you very much for your help.
- StephenBNov 16, 2025Guru - Experienced User
FWIW, the datasheet says it supports Insight Pro
Which I think requires a subscription.
- https://kb.netgear.com/000059597/What-do-I-need-to-know-about-NETGEAR-Insight-Pro-subscriptions
