THJ123
Oct 29, 2025Guide
Netgear Nighthawk M7 Pro 5G Wifi 7 Mobilruter
Hi I have bought an M7 Pro "Mod 7450" mobile router now, but which app should I use on this? I have tried several apps from Netgear, but none of them will connect. Using Iphone 15 pro. Thanks in ...
Fortra
Nov 30, 2025Luminary
Let me clear, so that there is no misunderstanding when you install the (Insight) app onto your mobile phone. You HAVE register it, while your using and setting up the (Insight) app on your phone. It's very important that you register it with the s/n, MR7450 of your mobile router!
