Washy53
Jun 10, 2021Follower
Netgear nighthawk mk1 MR1100-100
How do I turn on the data on this device SIM card is working I'm connected to the device but data is turned off! TIA
Blanca_O
Sep 01, 2021NETGEAR Employee Retired
Hi Washy53,
Welcome to NETGEAR Community!
Please check the display status on the device LCD if it says connected or not.
Make sire that network coverage is available in your area
Make sure that the SIM card is active and enabled with data services.
Kindly turn off and on the MR1100 and restart the computer or WiFi devices then check if it can go online.
Blanca
Community Team
