William_lives's avatar
Jul 01, 2019
NETGEAR nighthawk mobile M1 MR1100 connected to Nighthawk AC2300 smart wifi router R7000P via ether
Have a Netgear Nighthawk M1 (MR1100) connected via ethernet cord to a Nighthawk AC2300 smart wifi router. It seems to work but I have two signals. one from the mobile hotspot modem and one from the A...
  • W1lliam's avatar
    Jul 02, 2019
    You can configure M1 as IP Passthrough mode, that would disable M1's WiFi, also disable M1's DHCP Server, so you can have AC2300 as your main router, helps on M1's heat dissipation. William
