William_lives
Jul 01, 2019Follower
NETGEAR nighthawk mobile M1 MR1100 connected to Nighthawk AC2300 smart wifi router R7000P via ether
Have a Netgear Nighthawk M1 (MR1100) connected via ethernet cord to a Nighthawk AC2300 smart wifi router. It seems to work but I have two signals. one from the mobile hotspot modem and one from the A...
- Jul 02, 2019You can configure M1 as IP Passthrough mode, that would disable M1's WiFi, also disable M1's DHCP Server, so you can have AC2300 as your main router, helps on M1's heat dissipation. William
W1lliam
Jul 02, 2019Virtuoso
PatriotsUnited
Jul 29, 2019Aspirant
Hi, I have an odd issue. I'm tring to set up the M1 as a modem via LAN cable through the IP Passthrough setting.
I can get the inital set up right and all seems well. But the download speeds are bad! only around a 1Mb/s download. Where on WIFI through the M1 I get ~23Mb/s download...... I've tried several settings changes, setting the network address on the computer to a static IP: 192.168.1.50,; setting DNS to staic IP; turning off DHCP; letting the computer auto configure the network....usally it goes to a 10.x.x.x or a 169.x.x.x. Not sure whats going on here??? Any ideas? Once I get this figured out I'll be hocking the M1 to a more powerful dual band WIFI router for my house. Thanks all
- W1lliamJul 30, 2019VirtuosoYou can try to have Ethernet Switch plugged in between M1 and your PC, sometimes the problem is caused by interoperability for the Ethernet connection.
- PatriotsUnitedJul 31, 2019Aspirant
Great, thanks for the idea. I'll give that a shot and see how it goes.
