edithmargo06
Mar 14, 2021Follower
Netgear Nighthawk MR100 Hotspot ATT Unlocked
Hello. I purchased an unlocked ATT Netgear Nighthawk MR1100 off Ebay. I tried using a data only plan sim card from Cricket wireless. Before installing the SIM there was an message on the Hotspot stating "SIM not installed". I loaded my SIM card in but now getting message "Mobile Broadband is Disconnected". Please help.
Thank you.
1 Reply
- Blanca_ONETGEAR Employee Retired
Hi edithmargo06
Welcome to NETGEAR Community!
Kindly contact the carrier to check if you have the correct APN profile settings.
Blanca
Community Team
