Lincon
Sep 12, 2019Follower
Netgear Nighthawk MR1100 drops in and out even after adding a 7dBi Gain antennae
Hello everyone,, I live 48km from Perth at Serpentine on the coast side of the Darling Ranges.. My ADSL2 connection deteriorated over the past 5 years and drifted between 0.4mbps and 1.6mbps despit...
Blanca_O
Sep 18, 2019NETGEAR Employee Retired
Hi Lincon
Welcome to NETGEAR Community!
For poor performance issue, please try the following:
- Check the WiFi signal level . If WiFi signal is low, check the WiFi range options in UI and make sure it is not set to Short.
- Compare speedtest result when connected to 2.4GHz and 5GHz
- Try changing WiFi channel and check if there is any improvement
Blanca
Community Team
