NighthawkMR1100
Oct 31, 2022Aspirant
Netgear Nighthawk MR1100 External Antennas will actually boost signal?
I have a Netgear Nighthawk MR1100 and have tried several external antennas that state they will boost the cellular signal from a tower. They do not. After reading several chats, it seems W1lliam s...
NighthawkMR1100
Nov 01, 2022Aspirant
Thank you!
NETGEAR 6000450 MIMO Antenna with 2 TS-9 Connectors is the last external antenna that I tried. . Got it from Amazon. I think it's the same one you tried.
The one over at ebay you mentioned is a NETGEAR 6000450 MIMO Antenna for 3G/4G Air Card USB
Is this the same antenna?
FYI My current band is LTE B66
NighthawkMR1100
I read on another post to possibly connect a NETGEAR Orbi mesh WiFi system to the ethernet port of the Nighthawk. I've just ordered this and will try it out.
