mvink
Oct 16, 2020Initiate
Netgear Nighthawk MR1100 keeps dropping signal
My Nighthawk Mobile Hotspot MR1100 all of a sudden keeps dropping the signal and I have to completely reset the system for my devices to reconnect. I have the latest firmware update. Any advice?
Blanca_O
Oct 19, 2020NETGEAR Employee Retired
Hi mvink
Welcome to NETGEAR Community!
May we please know the device SKU (e.g. MR1100-100NAS)? This can be checked on the box of the product or on the barcode label
What is the firmware version?
How often does it disconnect?
Blanca
Community Team
- Blanca_OOct 19, 2020NETGEAR Employee Retired
Hi Malene666
Here's a reference for the AirCard Mobile Hotspot and Mobile Router Login Information
If it is not accepting the admin password then the next step is to factory reset the unit.
Blanca
Community Team
- mvinkOct 19, 2020Initiate
It is the MR1100 NIghthawk mobile router. Firmware is NTG9X50C_12.05.05.14. I have to reset it several times a day. It looks like it's connected in the wireless drop down on devices but there is no connectivity. SKU is 6420B MAC is 8C3BADF7706.
- nurse2020Nov 17, 2020Aspirant
I am having this same problem. Drops the internet several times a day!!
SKU: 6420B
F/W VER: NTG9X50C_12.05.05.14
- chrislangtonJul 14, 2022Aspirant
NETGEAR NIGHTHAWK M1 4GX GIG LTE ROUTER
TPPW4G-007F PASSWORD 89725691
- michaelkenwardJul 14, 2022Guru - Experienced User
You have a problem of some sort? You don't say.
Rather than hijacking someone else's conversation, you might do better to start your own with an explanation of what you are trying to fix along with details of what you are doing and where things go wrong.
If you do start a new conversation, you would do well to remove any personal information that might compromise your device.
