Amy_miranda's avatar
Amy_miranda
Follower
Mar 12, 2021
Netgear Nighthawk mr1100
How do I enable IP passage or bridge mode on my router?
1 Reply
  • michaelkenward's avatar
    michaelkenward
    Visit the support pages:
    Support | NETGEAR
    Feed in your model number and check the documentation for your hardware.
    Check the manual.
    You may have done this already. I can't tell from your message.
    You have posted your message in the section of this community given over to Nighthawk WiFi Routers. (This is easily done, given Netgear's complicated community structure.)
    While the MR1100 is specialist kit, many questions do apply to different types of device, so you might get responses here, but you might get more help, and find earlier questions and answers specific to your hardware, in the appropriate section for your device.
    That's probably here:
    Mobile Routers, Hotspots & Modems
    No need to repost there, unless you want to – that will just clutter up the place with duplicated messages – but you might find advice related to your hardware.
    I will ask the Netgear moderator to move your message.
