Yosimm
Mar 23, 2023Aspirant
Netgear nighthawk my 2100. No mobile broadband
Hi I have a o2 data only sim in my netgear mk2100 and WiFi is recognised but I cannot get mobile broadband. Just keeps saying “disconnected”
It might be only provisioned for phones.
did you check with O2?
Yosimm wrote:
Hi I have a o2 data only sim in my netgear mk2100 ...What's that?
I can find no MK2100 in the Netgear system. (MKXX usually denotes a Mesh router.) Perhaps you mean MR2100
Is it a mobile hotspot modem? If so, try here:
Mobile Routers, Hotspots & Modems
- YosimmAspirantYes sorry you are correct. MR2100. Thank you
