ANTONYVA
Mar 08, 2024Follower
NETGEAR Nighthawk RAX120 AX6000 Dual-Band 12-Stream can connect with MR100?
I have NETGEAR Nighthawk RAX120 AX6000 Dual-Band 12-Stream and ,I am using MR100 Wireless modem. i need 2 more LAN line ,so I can connect to NETGEAR Nighthawk RAX120 AX6000 Dual-Band 12-Stream ? Th...
Mar 08, 2024Guru - Experienced User
this statement was rather disjointed and confusing.
I'm not sure exactly what you're trying to do.
You have the Mr1100 with the RAX120 connected to it.
And you're needing extra lan ports?
A cheap unmanaged switch can be beneficial
