hegmannkris's avatar
hegmannkris
Follower
Nov 19, 2020
Netgear nighthawk will not turn on.
I have a one week old Netgear nighthawk that has been working fairly well. Not great signal but ok. Came home from work tonight and the thing is just dead. It was left plugged in. And now I just changed outlets thinking hat might be something but as soon as I plug it in it tries to start up. I get a blue light flash, then orange light flash, then the screen tries to start and it shuts down. Ideas or thoughts?
  • Blanca_O's avatar
    Blanca_O
    NETGEAR Employee Retired
    Hi hegmannkris
    Welcome to NETGEAR Community!
    What's the exact model number and version of your NETGEAR device.
    You can try resetting the router back to factory settings.
    Blanca
    Community Team
    • michaelkenward's avatar
      michaelkenward
      Blanca
      Community Team
      You have repled to, and unleashed, a bout of linkspam.
      Look at all of the messages here. Delete them all. This one too.
      • Roykim34's avatar
        Roykim34
        Removing battery and SIM card reset mine, as well!!  Thank you, internet hero, from much headache and anger!!
