Doral1
Jan 26, 2022Aspirant
Netgear nighthawk
2022-01-25 08:29 AM Hello, I have 2 questions: 1. How can I unlock my sim PINCODE on the netgear nighthawk M1? I have a Swiss SIMCard and also the DATA is not working either. 2. when I put in a F...
Doral1
Feb 02, 2022Aspirant
Hello, sorry the correct SKU number is: MR1100-100EUS.
kind regards,
Claudia SCHENK
JohnPeng
Feb 02, 2022NETGEAR Expert
kind regards,
Claudia SCHENK
Seems like your SIM card has PIN code enabled. You need to log in to MR1100 WebUI to enter the SIM PIN. Or the SIM will not work for data.
For using French SIM, please log in to WebUI and enter correct APN for the SIM card. Please refer to the QSG or User Manual for how to do this.
Thanks
