Dipster
Aug 22, 2023Follower
netgear nighthawrk m2 help
hi i am new and just got the netgear nighthawk m2 but im trying to use the Ethernet port to plug the cable into my android box but cannot seem to get it working
ive tryed one way witch is going onto the netgear app then to mobile router setup
then to ip passthrough then i turn on disables wifi on mobile router
then to DHCP where it says
use mobile router as DHCP is ticked
TETHERING
turn of wifi when tethering is turned off
ETHERNET is disabled
just need some help please as its driving me mad
im trying to just use my ethernet cable for my box so the box picks it up as just ethernet is plugged in
thanks
No RepliesBe the first to reply
