adbeam
Mar 29, 2019Aspirant
Netgear [Sierra Wireless] 349u AT&T Beam Aircard
Hello, I need some assistance. Cannot find info on compatibilty [or support] with the above USB aircard with Netgear Routers. Pointing me to a list of supporting routers would be great help. Thanks D...
Blanca_O
Apr 04, 2019NETGEAR Employee Retired
Hi adbeam
Welcome to NETGEAR Community!
Can you please confirm the device model number? We cannot find any information of the said model. If this unit is from At&T, you can this information from them.
Blanca
Community Team
- adbeamApr 05, 2019Aspirant
I am sorry I did not realize my typo error. It's a Sierra Wireless 340u Beam which was taken over by Netgear. And it's obtained thru AT&T. Any additional info needed please advise. Thanks don
- Blanca_OApr 14, 2019NETGEAR Employee Retired
Hi adbeam
You may check the following links to check compatibility:
https://kb.netgear.com/24147/DGN2200M-Compatible-3G-USB-Modems
https://kb.netgear.com/24141/MBRN3000-Compatible-3G-USB-ModemsCan I use my AirCard USB modem with my 3rd party router?
Blanca
Community Team
