fatallordes's avatar
fatallordes
Follower
Apr 29, 2020
Netgear Telstra 4G Aircard 320u Lights Flashing
My Telstra Aircard 320u USB modem has been working fine until two days ago.  Since then when I plug it in, the power light flashes blue and amber.  Sometimes it connects to telstra (all lights blue) but only for a minute or two and then the power light starts flashing blue and amber and it disconnects.  What is wrong with it and how do I fix it?  I've tried on TP_Link router (which it has always worked on until two days ago) and my laptop.  Same result on both so it is definately the modem dongle.
1 Reply
  • Blanca_O's avatar
    Blanca_O
    NETGEAR Employee Retired
    Hi fatallordes
    Welcome to NETGEAR Community!
    We suggest that you call Telstra to better isolate the issue for possible hardware problem.
    Blanca
    Community Team
