Jashill
Nov 27, 2020Aspirant
Netgear Wireless internet IFWA-40
AT&T is recommending that I purchase a Netgear Wireless Internet Model IFWA-40 unit to improve my service. I currently have a Hotspot that I use for internet service and a wireless home phone. Neit...
Nov 28, 2020Guru - Experienced User
If your att mobile hotspot has bad coverage and so does your phones (do they?), a different device isn't suddenly going to give you better coverage.
You need a better signal from att whether that be them adding a tower (doubtful), you putting up a signal booster somewhere, or even adding an antenna at a high point to get coverage. Your service is only going to be as good as the signal ATT about to get to you.
Jashill
Nov 28, 2020Aspirant
Thanks, Looks like I would be better changing to a cable company instead of the wireless. Thanks again.
