anthony12728282
Feb 10, 2018Follower
Netgear Wireless-N Dual Band Router
Why is my Ethernet LED blinking green? It’s preventing me from connecting to my wifi network on my Xbox One.
JasonN
Feb 12, 2018NETGEAR Employee Retired
Hi anthony,
The blinking green LED on the ethernet port is normal. It means that it has a Gigabit Ethernet connection. Please refer to the link below for the kb guide of LED meaning. Is your router to the current firmware? If so, did you do a factory reset after the update? Have you checked the configurations on the xbox side? can other devices connect to the router?
Ethernet LEDs
The LED color indicates the speed: white or green for Gigabit Ethernet connections and amber for 100 Mbps or 10 Mbps Ethernet connections.
- Off. No device is connected to this Ethernet port.
- Solid. A powered-on device is connected to the Ethernet port.
- Blinking. The port is sending or receiving traffic.
https://kb.netgear.com/24244/Understanding-NETGEAR-LED-Symbols
- Jason N
