eburden97
Jan 17, 2024Follower
Netgear Zain M5 does not provide internet
I recently bought a Zain M5 and have a sim with data on it. The puck connects to data but when I connect any if my devices to it I don't get any internet. I've tried resetting it and looking for updat...
michaelkenward
Jan 17, 2024Guru - Experienced User
What's that?
I find no Zain M5 in Netgear's system.
M5 isn't a model number either. It is a label put on a number of mobile routers. MR5200?
- Blanca_OJan 22, 2024NETGEAR Employee Retired
Hi eburden97,
If you are connected to the mobile router but cannot connect to the Internet, I suggest to do the following:
• Check the display status on the mobile router’s LCD screen.
• Make sure that network coverage is available in your area.
• Make sure that your micro SIM card is active and enabled with data services.
• Confirm that your account is activated and that no other Internet connections are
active.
• Switch your mobile router off and on and restart your computer or WiFi device.Regards,
Blanca
Community Team
