cinco3
Mar 16, 2020Follower
Netgear89 Microwave Interference
I get disconnected from any/all devices when I run my microwave. What can I do to fix this? I see others have said to "change the channel"... how do you do that? thanks!
Mar 17, 2020Guru - Experienced User
a quick search shows you how.
https://kb.netgear.com/23783/Improving-2-4Ghz-Wireless-Performance-by-Changing-Channel
If that doesn't fix it, I'd look at getting rid of the microwave
