devyq8
Apr 30, 2018Aspirant
netgeart m1 battery problem
hi there ,, im having issue with my brand new netgear m1 ,, the router stop charging it self and recharge again ! the cabel was fine plugged in walle ,, and the device even not getting heat, so an...
devyq8
May 01, 2018Aspirant
no one ,, i just wana know is this normal charging issue ?
- JasonNMay 01, 2018NETGEAR Employee Retired
Hi devyq8,
Can you be more specific?
Is the device being charged with the battery in?
If so, does your screen show that it is charging?
Does your device turn on with the cable without the battery?
Please let me know. :]
- Jason N
- JasonNMay 08, 2018NETGEAR Employee Retired
Hi devyq8,
I just wanted to check in with you and see if your issue has been resolved. If not, then I would like to gather more information from you. If you can please answer the questions I have provided in my earlier post that would be much appreciated. This will help narrow down a resolution.
- Jason N
