devyq8
Apr 30, 2018Aspirant
netgeart m1 battery problem
hi there ,, im having issue with my brand new netgear m1 ,, the router stop charging it self and recharge again ! the cabel was fine plugged in walle ,, and the device even not getting heat, so an...
JasonN
May 22, 2018NETGEAR Employee Retired
Hi n3t,
Thank you for posting the battery issue in a separate post. It is best to charge the device without use so it is not overheating. Like I said in the other thread, It is bad to use your device while charging your battery at the same time because this will reduce your battery life in the long run.
Please let me know if you have any other questions. :]
- Jason N
W1lliam
May 22, 2018Virtuoso
Just wonder if not suggested to charge your battery while using MR1100, then how to do off-line charge as I can't find any of charger out there.
William
