ErikHedman
Sep 05, 2022Aspirant
Network logging with Nighthawk M1
Blanca_O
Sep 05, 2022NETGEAR Employee Retired
Hi ErikHedman,
Welcome to NETGEAR Community!
Please describe further the issue you're facing with the Nighthawk M1.
Blanca
Community Team
ErikHedman
Sep 06, 2022Aspirant
Hi, I would like to monitor the mobile interface towards the internet provider. Get like a tcp dump or wireshark trace. Including the dhcp request and replay messages with lease time etc. No problem to do the http connect with the unit but I haven´t been able to use the net rlogin or establish the usbc connection. I have enable charge+theter. Please advice how to get the logging from the service provider. Thanks Erik
- ErikHedmanSep 08, 2022AspirantMay I get an updte on this issue? It is importaint for me but also for Netgear since my ip network provider telia blames the router for a failure that I think belongs to their network. I need to get the traces that shows how the dhcp requests are handled. As second question is is possible to monitor the radio part when it comes to a stable radio connection or if the router are moving between bases even when it is placed on my table alk the time?Please refer back with information.
