ErikHedman
Sep 05, 2022Aspirant
Network logging with Nighthawk M1
ErikHedman
Sep 06, 2022Aspirant
Hi, I would like to monitor the mobile interface towards the internet provider. Get like a tcp dump or wireshark trace. Including the dhcp request and replay messages with lease time etc. No problem to do the http connect with the unit but I haven´t been able to use the net rlogin or establish the usbc connection. I have enable charge+theter. Please advice how to get the logging from the service provider. Thanks Erik
ErikHedman
Sep 08, 2022Aspirant
May I get an updte on this issue? It is importaint for me but also for Netgear since my ip network provider telia blames the router for a failure that I think belongs to their network. I need to get the traces that shows how the dhcp requests are handled. As second question is is possible to monitor the radio part when it comes to a stable radio connection or if the router are moving between bases even when it is placed on my table alk the time?Please refer back with information.
