jl1415
Mar 06, 2025Aspirant
Network Status log
I would like to access a log that stores which service my the modern is using to connect the internet.
aznejaro
Could you be more specific? You look for the router logs?
jl1415
The Web GUI doesn't have any logs.
The LM1200 has a failover system that will switch from wired to LTE if the wired connection drops out. I would l like to be able see a log with time stamp when this happens.
