Beugene
Feb 15, 2023Follower
New 4G internet help
I am setting up an in home wifi system. I believe I'll be using an At&t sim card for my provider. I need help on the best equipment to use. The house is approximately 3000 sq ft and will have less...
Feb 15, 2023Guru - Experienced User
Cell is your only service? Its not the greatest for gaming.
I'd look at getting a modem only hotspot like the LM1200 (or a 5g hotspot if you have that option).
Then just add a standard mesh system to it. That way if you do get dsl/cable/fibre/starlink you can keep using your mesh system with whatever gateway you get.
