Beugene
Feb 15, 2023Follower
New 4G internet help
I am setting up an in home wifi system. I believe I'll be using an At&t sim card for my provider. I need help on the best equipment to use. The house is approximately 3000 sq ft and will have less...
Feb 15, 2023Guru - Experienced User
Cell is your only service? Its not the greatest for gaming.
I'd look at getting a modem only hotspot like the LM1200 (or a 5g hotspot if you have that option).
Then just add a standard mesh system to it. That way if you do get dsl/cable/fibre/starlink you can keep using your mesh system with whatever gateway you get.
JohnPeng
Feb 16, 2023NETGEAR Expert
It also depends on the wireless coverage at your home. If it is too far from the cell tower, the data speed be pretty bad.
Thanks
John
