JSchnee21
Mar 22, 2018Virtuoso
New Firmware -- AT&T USA
Hi Everyone, There is in fact a new firmware for AT&T rolling out now. I'm trying to update, but first download attempt failed. I did two factory resets (one soft through the web admin, and the...
Rcracerg911
Mar 29, 2018Aspirant
What you mean by manual reboot? Do you mean having to pull the battery to get it started again? Or is the unit on but Wi-Fi isn’t being broadcasted? Because if it’s the former, then there is another thread that explains a similar situation. Thanks.
winger13
Mar 29, 2018Guide
I am unsure what you are talking about when you refer to "former" .
Can you re-write your message ?
- Rcracerg911Mar 29, 2018AspirantI was talk about the first case I mentioned ( you need to pull the battery out then back in to restart the unit) . Is this what you mean by “ manual reboot” ?
