JSchnee21
Mar 22, 2018Virtuoso
New Firmware -- AT&T USA
Hi Everyone, There is in fact a new firmware for AT&T rolling out now. I'm trying to update, but first download attempt failed. I did two factory resets (one soft through the web admin, and the...
JSchnee21
Ok,
Got my work laptop fired up with inSSIDer. From the negotiated PHY rates, it appears the MR1100 is in fact MIMO 2x2.
With 5.8GHz @ 40Mhz I get a max PHY rate of 360Mbit (aka ~216Mbit usable). At 5.8GHz @ 80MHz I get a max PHY rate of 866.7 Mbit (~520Mbit usable)
Signal (dBm) seemed to drop only ~3-5dBm with 80Mhz enabled. But this was by no means a scientific test. In general signal strength and useful range general decreases with wider channels. Which is why I want to use a 20MHz bandwith for 5.8GHz.
More info here
http://www.arubanetworks.com/assets/wp/WP_80211acInDepth.pdf
Not sure if the MR1100 does band steering or not. I don't see any settings. I typically run my 2.4GHz and 5.8GHz networks with separate SSID's.
-Jonathan
UK-based
Mar 30, 2018Luminary
JSchnee21: I just like to thank you for your detailed and informative posts on this and other topics. You're clearly spending a lot of time doing research into the M1 and are very kindly sharing your findings with us. Keep up the good work - it's much appreciated :smileywink:.
