JSchnee21
Sep 23, 2018Virtuoso
New Firmware -- Overtemp warning
Saw a new message and icon on my mr1100 since updating to the most recent AT&T firmware a week or so ago.
While it's good that the mr1100 now tells you why it is not charging -- due to battery/devi...
Blanca_O
Sep 23, 2018NETGEAR Employee Retired
Hi JSchnee21,
Welcome to NETGEAR Community!
What is the current firmware version?
Do you have Ethernet standby enabled?
What is the temperature of the battery being reported on the device diagnostic page on the MR1100 UI?
Blanca
Community Team
JSchnee21
Sep 24, 2018Virtuoso
HI Blanca,
Thanks for following up. At the time, I believe Ethernet standby was "disabled." When Ethernet is on (aka not disabled) the idle train on the battery is definately increased which could elevate the unit and battery temperatures. But since then I've changed it to 2min as I am not using Ethernet right now (but I do from time to time)
Here are my unit's details:
MR1100-1A1NAS, H/W 1.0, SKU 6112B
Purchased March 2018
FW: NTG9X50C_12.05.05.00
FW Date: 2018/07/25, AT&T Wi-Fi
PRI: 03.12
Web: MR1100-1A1NAS_04.01.70.02
Current Temp: 26 degrees C (78.8F)*
Battery Temp: 26 degrees C (78.8F)*
*Unit was turned off overnight sitting inside my house whose
ambient temperature is 71F (21.67C)
Currently, at this temperature, the mr1100 will accept a charge. I didn't check the temp
when it was refusing a charge a couple days ago, but from fealing it in my hand it was definately warmer at that time -- perhaps approximately body temperature.
Compared to ambient, the temperature sensors definately have at least a 3 to 4 degrees C positive bias (aka calibration error).
https://en.wikipedia.org/wiki/Lithium-ion_battery
It's generally accepted that Lithium Ion batteries have a working and charging range of at least 5C to 45C.
Though some reputable sources claim that up to 60C is fine
https://ehs.mit.edu/site/sites/default/files/documents/Lithium%20Battery%20Safety%20Guidance.pdf
For example, my iPhone which sits in my pocket which is ~35C all day readilly accepts a charge under heavy use on at hot summers day when the device it at least 50C.
In order for the MR1100 to be practical, it must be able to accept a charge while simultaneously under normal to heavy data use (wifi, ethernet USB) under ambient conditions that are at least 75-85F.
Next time I get the message that the unit is unable to charge, I'll try to get the temperatures for you.
Thank you,
Jonathan
- JSchnee21Sep 24, 2018Virtuoso
As another piece of data. I just ran a few speed tests on the unit -- maybe 5 -- from my phone which is tethered via Wifi (5.8Ghz). And the temperatures (as reported on the Web Admin page) have already climbed to:
Current Temperature 34C
Battery Temperature 30C
Now after sitting idle for a few minutes the current temperature has fallen back to 31C.
Once again, ambient temperature is only 21 to 22C.
-Jonathan
