JSchnee21
Sep 23, 2018Virtuoso
New Firmware -- Overtemp warning
Saw a new message and icon on my mr1100 since updating to the most recent AT&T firmware a week or so ago.
While it's good that the mr1100 now tells you why it is not charging -- due to battery/devi...
vanillaknot
Sep 26, 2018Star
I discovered this thread just this evening.
I first got an mr1100 last December. In short order, it was clear that the battery wouldn't charge very far, getting stuck <20% and never improving. I thought I had a bad battery. I didn't think much of it because the device has been always at home. But it needs to go genuinely mobile soon, so I finally (this past Monday) got a warranty replacement of the entire unit because AT&T aren't equipped to replace just the battery. New unit came to life without incident after interacting with AT&T on the phone for ICCID & IMEI. Settings were loaded from saved backup.
New unit fired up and immediately requested firmware update. Now I have new LAA and AP isolation capabilities, as well as this battery nonsense. My new unit is again not charging, stuck below 40%. See attached image for stats. Device screen says "Battery Heat Mode -- Battery charging stopped due to high device temperature." It's mildly idiotic for it to be panicking over heat yet also report "battery status - normal" and "battery charge status - yes".
I'm guessing my original unit was fine as well, but just didn't have the firmware smarts to say what it thought was wrong. Frankly, this is inane -- my unit sits on a table in my home office 95% of the time, always plugged in. How exactly is it getting so warm? Why are its tolerances so finnicky when this is as bland an environment as one could ask for?
Unit is Gen1, firmware 12.05.05.00, build date 2018/07/25. Ethernet standby is disabled (attached to house network on a Netgear switch, for wired printer & other devices) and unit is always on, acting as the external gateway for the household. Having ethernet on is no excuse for reacting badly to warmth.
JSchnee21
Sep 27, 2018Virtuoso
Hi vanillaknot,
I've actually never seen the behavior you describe where the unit starts charging but then gets to a certain percentage and stops. While I agree it could be a thermal issue, I would not expect charging to stop at the same battery percentage each time -- unless the battery (or charging circuit) were defective as you already surmised.
So you had your unit replaced under warranty and the replacement is still a Gen1? That's surprising to me, I didn't think AT&T was still stocking the Gen1. How did you go about getting it replaced? Corporate over the phone? Or a local store? Did they hassle you or was it a piece of cake?
Total agree that the thermal envelope parameters are crazy small and/or the placement of the sensors is too close to a heat source or miscalibrated. Or all of the above.
Here are two things I would try:
1) Put your mr1100 and battery in the refridgerator for a few hours and then try to charge it. If it is truly a thermal issue you should be able to charge further befor tripping the thermal overload. While charging, turn the unit upside down and remove the back cover. If you have a small fan or "Cool pack" / "Blue Ice" etc. you can cool it down as it charges -- but be careful you don't get condensation/liquid water in the unit.
2) I threw out the stock charger that came with it long ago. And am using an Anker QC3 charger. This charges the battery at a faster rate and higher voltage and may help it get past an internal inefficiences more easily. The mr1100 only supports QC2 I believe, but the Anker falls back. I'm using both the original USB to USC cord from Netgear and one I bought from Anker -- both seem to perform the same
3) I only usually charge my mr1100 when it is turned off. Aka my kids use it in the car to watch shows, when they get home I take the mr1100, put it on charge, verify the charging indicator comes on, then turn off the unit (so it doesn't interfere with the Wifi in my house). Generally, unless the unit is too warm it will start charging right away. But sometimes the USBC connection doesn't "sync" and nothing happens. At which point I unplug the USBC, wait and few seconds and plug it back in or switch to the other USBC wire I have. It seems there is some negotiation that takes place. Once I'm good I shutdown the unit.
Some have claimed that when the unit cools down, it will start charging automatically. Also that when left plugged in as the battery drains it will start charging automaticlly and then stop when full.
If none of these things work, I suggest creating a real support ticket with Netgear
Good luck,
Jonathan
- vanillaknotSep 27, 2018Star
Yes. Apparently it's a refurb unit, guaranteed as though new.
These are good thoughts, but [a] limited in applicability, because at best they will show the extent of the problem without solving it because the device will grow warm again anyhow once it's back in normal office temps, and [b] the device is never off because normally it's the household gateway -- everything in the house depends on it for Internet access. I can try the fridge test briefly, but the device's usage needs don't provide for just turning it off every time I want it to charge. It should stay plugged in and charged at home all of the time, able to withstand the occasional power failure uneventfully.
--karl
PS/FYI- My reason for going this route at all was that I gave up on Comcast last November, when their latest 2-yr contract expired and they started wanting $180+/mo for TV+Internet. I tossed Comcast, got this AT&T hotspot as part of the genuine "unlimited" plan, plus DirecTV (also through AT&T) for a total that's barely 1/3 of Comcast's cost, for net savings $1k+/yr. Speed is not the greatest -- being in rural nowhere doesn't help -- but I'm still happy as long as I stay above, say, 10Mbps. My monthly data utilization is always above 200Gbytes: Yay unlimited plan. :-)
- JSchnee21Sep 27, 2018Virtuoso
Agreed. You could just pull the battery out entirely, and run the unit on a QC2 or QC3 charger plugged into a regular old UPS. Not ideal, but at least the mr1100 would run a lot cooler.
- vanillaknotOct 06, 2018Star
FYI I finally got around to calling AT&T about this heat problem again. Explained first unit return, second unit setup gaining new firmware, now with battery complaint and charge stoppage.
This time, the rep found that they can replace just the battery. This was unexpected to him -- he said he'd had to replace mr1100s before and always had to do whole unit, not just battery, and was surprised when batteries were listed in stock today.
So I have a battery coming. Maybe something good has happened, maybe it's been redesigned not to be so sensitive to the charging process so as not to get so warm. We'll see.
