JSchnee21
Sep 23, 2018Virtuoso
New Firmware -- Overtemp warning
Saw a new message and icon on my mr1100 since updating to the most recent AT&T firmware a week or so ago.
While it's good that the mr1100 now tells you why it is not charging -- due to battery/devi...
jpainter01
Aug 23, 2019Tutor
Does the MR1100 Nighthawk log errors that record that it has overheated at some time?
JSchnee21 wrote:Saw a new message and icon on my mr1100 since updating to the most recent AT&T firmware a week or so ago.
While it's good that the mr1100 now tells you why it is not charging -- due to battery/device over temp. Both in words and with a spiffy new icon (see attached).
But, it doesn't change the fact that the unit is way too temperature sensitive. The otherday I went to charge my device after only an hour or so normal usage. The mr1100 was slighlty warm in my hand from usage on a mild summers day (in the shade). And it refused to charge.
I had to turn the unit off, remove the back cover, and let it sit open for 30min or so to get it to accept a charge. Of course then, when I plugged in the power to charge the unit annoyingly turns on. So then I had to wait for it to boot, then shut it down, all because the safety temp thresholds are way to low (or sensors are not properly calibrated).
- vanillaknotAug 23, 2019Star
One of the failings of the MR1100 is that it provides no user-accessible logging at all.
