nglcour
Mar 04, 2024Aspirant
New firmware causes no connection with mobile network
Hi, Since the firmware update to this device last month I haven't been able to get the device to connect to the EE network, despite a reset and reentering the APN settings. How can I go back ...
- Mar 15, 2024
Just spent a couple of hours trying to resolve it. An EE sim not working, but a 3 and O2 sim worked fine.
(Seen a response on O2 forums about it not working with O2, but working with EE)
Solution was to add a secondary APN (default is 'btinernet.bt.com', secondary is 'everywhere'), set the connection to 4G only, change to a different APN (default --> secondary) and it started working. Then we changed it from 4G to 4G+5G and then back to the default APN.
My theory is that it's caused by the recent removal of 3G.
MidnightDuck
Mar 15, 2024Aspirant
nglcour
Mar 18, 2024Aspirant
Whatever the cause your steps fixed it, much appreciated.
