JSchnee21
Sep 18, 2018Virtuoso
New Firmware LAA Support?
So,
My Gen1 mr1100 just got a firmware update to version
NTG9X50C_12.05.05.00
Of course there are no release notes as usual. From the chatter on Reddit, and my own investigation it app...
JSchnee21
Sep 19, 2018Virtuoso
Thanks to some postings on Reddit, I found this really great link on AT&T's website which has release notes and a few quick fixes for common issues!
"Here is the current update: NTG9X50C_12.05.05.00_ATT_03.12
The details
Release date: September 17, 2018
Firmware version: NTG9X50C_12.05.05.00_ATT_03.12
File size: 109MB
The updates
What's changing: AP isolation and Licensed Assisted Access (LAA)"
I thought I had noticed a new feature for "AP isolation" but wasn't sure. This feature should prevent Wifi associated clients from being able to "see" and communicate between one another (not generally used in a home setting).
Still no official word on whether the Gen1 mr1100 supports LAA or only Gen2.
- JSchnee21Sep 20, 2018Virtuoso
Does anyone live in an LAA enabled market? It would be great to get some preliminary benchmarks using LAA for:
1) Gen1 vs. Gen2
2) Different modes of tethering (Ethernet, USB, 2.4Ghz)
Markets
http://about.att.com/story/att_builds_on_5g_foundation_in_more_than_100_new_markets.html
Up to 750Mbit
http://about.att.com/story/lte_licensed_assisted_access_field_trials.html
I had heard that the mr1100 has an internal routing/NAT performance limitation of around 500mbit from WAN/LAN.
- vanillaknotSep 25, 2018Star
I've had an mr1100 since last December. I live outside Pittsburgh, which is supposed to be one of the new LAA markets, but it is possible I live too far away (~40 miles northwest) to be part of that deployment. How or where do I learn whether my area is LAA-enabled? My search foo on this question seems weak.
Also, how do I distinguish Gen1 -vs Gen2 hardware? Just yesterday, I did a warranty replacement of my original mr1100 because it refused to charge the battery. I had surmised that the battery itself is bad, but I was told that AT&T can't replace just the battery, they have to replace the whole unit. OK, fine, now I've got a new mr100 in place, and I don't know where the differences lie.
The new unit woke up almost immediately requesting firmware upgrade, consequent to which I discovered new LAA capability (with configuration restriction as noted) and came looking here for more answers.
- JSchnee21Sep 25, 2018Virtuoso
Hi vanillaknot, welcome!
Here are the abbreviated model details:
Hardware Version 1 -- MR1100-1A1NAS
Hardware Version 2 -- MR1100-2A1NAS
There are subversions of each as well depending on whether the unit has the retail or corporate firmware (most are retail).
I don't think LAA has been deployed in Pittsburgh yet
https://www.fiercewireless.com/wireless/at-t-more-than-half-way-to-enabling-laa-24-markets-year
-Jonathan
The thing with LAA is that it is hyperlocal. So far, I've not heard of any deployments which are more than a few city blocks in area.
