JSchnee21
Jun 20, 2018Virtuoso
New Firmware Released for AT&T 12.02.06.01
Hi Everyone,
It seems a new firmware was released today for the US AT&T version of the MR1100. I manually check for an update at 11:55pm on 19-Jun-2018.
In my case:
Hardware Version 1....
bkvargyas
Jul 10, 2018Aspirant
How does anyone get the firmware to update on this ATT MR1100? I seem to be infinitely stuck at 10.20.05.02, and my software always says "Up to date". I've tried battery in, battery out. Factory result multiple times, taking the unit on trips to see if location matters (it doesn't). Different power supplies....nothing will update the firmware on my unit --- HELP! And I've got that battery problem that if it drains, it's very hard to get it to recharge again.... About to take it to an ATT store to see if I can get the unit swapped out to a different one.
JSchnee21
Jul 10, 2018Virtuoso
Hi bkvargyas,
Very strange, I've had no issues detecting, downloading, and installing new firmwares from AT&T/Netgear. I would definately take it to and AT&T store and try to get it swapped out. Hopefully you'll get the newer hardware version which supports Band 14 at the same time.
-Jonathan
