MouseNeumeister
Nov 04, 2022Aspirant
New Product Request
Dear NETGEAR, Please build a NETGEAR Nighthawk 5G LTE Modem + WiFi 6E Router Combo with at least the capabilities of your Nighthawk AX11000 Tri-Band WiFi 6E Router (RAXE500) -- I'm ready for it! VR...
Nov 06, 2022Guru - Experienced User
You mean like the MR6500? With 6E capability and a 2.5gig port?
https://www.netgear.com/home/mobile-wifi/hotspots/mr6500/
MouseNeumeister
Nov 12, 2022Aspirant
Yes, something like the MR6500 with 6E capability and a 2.5gig port, but with the ability to also connect to a cable modem, automatically switch between the cable modem and the 5G LTE connection if / when the cable service goes out, and provide all the other capabilities / features of a high-end router like the RAXE500, e.g., reliable connections for up to 60 devices across 3,500 sq. ft., ~4 LAN ports, ~2 USB ports, etc. Essentially, I'm suggesting taking something like the RAXE500 and adding the 5G LTE capability to it.
