Nawem
Mar 13, 2021Aspirant
Nighhawk mr1100 Mobile app connects from iphone, but from iPad mini, it says the router is unsupport
Nighthawk MR1100 mobile router Netgear mobile app My iphone connects to the router just fine. Using the same app on the same network on my iPad produces an error message saying Incorrect Wifi ...
michaelkenward
Mar 14, 2021Guru - Experienced User
Nawem wrote:
Clearly it IS compatible, but the iPad won't connect to it!
What makes you think the router is the guilty party?
You have posted your message in the section of this community given over to Nighthawk WiFi Routers. (This is easily done, given Netgear's complicated community structure.)
Many questions apply to different types of device, so you might get responses here, but you might get more help, and find earlier questions and answers specific to your hardware, in the appropriate section for your device. That's probably here:
Mobile Routers, Hotspots & Modems
I will ask the Netgear moderator to move your message.
- NawemMar 21, 2021AspirantSame app used on iPhone, and iPad mini. When using app from iPad, it says the router is not compatible! Works fine from iPhone!
Why not from iPad?- michaelkenwardMar 21, 2021Guru - Experienced User
Why not from iPad?Why do you think the mr1100 is the problem rather than your iPad?
- NawemMar 21, 2021AspirantI never said any such thing. I simply said it will connect from one device, and not the other, and I provided the error message that appeared.
